Battery Reading <1 volt???
Old Jul 19, 2008 | 01:05 AM
martinjp's Avatar
martinjp
Default Battery Reading <1 volt???
My battery went dead on my 78. I pulled it out of the car and the voltage measured less than one volt. I have never seen a battery that low. Any ideas??
Old Jul 19, 2008 | 01:39 AM
Project80's Avatar
Project80
If it went dead very suddenly, the internal plates may have separated. Regardless, once a battery falls below that 6 or 7 volts level, they are not considered very healthy.
Old Jul 19, 2008 | 06:56 AM
The Money Pit's Avatar
The Money Pit
Replace the battery for sure, and when you do,connect an ammeter in line with the positive battery lead. With the car no running,sit inside with the doors closed,nothing turned on, and see if you have a current draw. Mine had almost 10 amps,and I started pulling fuses to isolate the draw. Turned out to be the alarm fuse.
Now I use the Doberman for an alarm
Old Jul 19, 2008 | 07:06 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Also check the alternator and the rest of the charging system.
Old Jul 19, 2008 | 11:34 AM
dannyman's Avatar
dannyman
Have it checked at your local supplier.
You must have had a large draw to knock it down to 1 volt. How long was it sitting before you realized that the battery was dead?
Old Jul 19, 2008 | 04:55 PM
martinjp's Avatar
martinjp
The car was only sitting for one week. I had never seen a battery go that low before. Time to get the old meter out and start checking all of the charging system. I would much rather be waxing it!
Old Jul 19, 2008 | 06:12 PM
Jud Chapin's Avatar
Jud Chapin
Actually batteries can go to "0" volts.
Old Jul 20, 2008 | 08:49 AM
FB007's Avatar
FB007
Actually, the sediment at the bottom shorts out the plates, resulting in dead cells.
Old Jul 20, 2008 | 10:42 AM
Project80's Avatar
Project80
Actually, this has nothing to do with battery failure due to a mechanical separation of the plates.
To Battery Reading <1 volt???
