I need some TPI advice.
same concept, same up/over induction, same everything, really, just a total different install...lower...
so, I got a set of rails/regulator and mani for 150 bux off epay....
now having gotten them I was VERY discouraged for over a week, then I got a set of Felpro intake gaskets and started lining up stuff.... drilled the holes I needed for the L98 heads, went to Harbor Freight and bought a FORSTNER bit set....the whole set was only 7-8 bux last winter here....
I cut the end off the on the 7/8 size and then took a grinder to shape the BACKSIDE of the bit to cut in REVERSE when pushed in from top side, and then chucked into a hand drill in Reverse rotation....it cut the intake metal to a plane agreeing with the L98 heads....
then the tricky part....the welding...for the front outputs for the water and ordering the remote thermostat housing....then the more complex install of the dizzy in back for THAT you need a guy who TIG welds and make no bones about it....that guy has some awful fancy machine tools OR a couple bungs off Summit Racing.com and you can have them TIGd in and over with....
I put a couple pipes in back for flow to the heater return line....
IF you takes your time you CAN do it, but you have to do one thing at a time and it not necessary to tear down your car to do it either.....
then again, I have BTDT many times so know a few tricks...numero UNO is patience.....and study....
