Piston slap question...
.018 is minimum, but what is "too much"???According to the calculations, the bores are approx 4.005", confirmed with a dial caliper (bores are between 4.004" to 4.006" at the top of the cylinders. Ring gap is approx .001 to 002 less at the bottom of the bores than at the top.
I'd much, much rather stay with the (nice) TRW 11.25:1 forged aluminum pistons than have to spring for 10-overs (just now). What do you experts think about me buying "10-over" rings and re-gapping them? I know for sure I will want to go very lightly over the bores with the ball hone - the holes are big enough already
. Aside from some piston slap (which will most likely be drown out by the side pipes anyway) do ya see any issues w/ what I have in mind??BTW, the holes appear to be round (as in no gaps around the new ring inserted into the bore).
Bottom line Q: Use the 5-under pistons and re-gap some 10-over rings (save some bucks and live w/ the noise) or bite the bullet and bore 10-over and get new pistons
Thanks in advance, guys.
Paul.
they also make one of the best filters...
Hans
IMHO ... quik-checking bore w/ a typical dial caliper OK ... but you need to accurately measure bores & skirts ... & a caliper ain't good enough to confirm that.
You might "get by" having auto machine shop KNURL your pistons' skirts and file-fitting rings ... might be sugar ... might be sheet.
http://en.wikipedia.org/wiki/Knurling
I'd measure it correctly ... and if sloppy ... bore w/ new oversize pistons.
