diff side yoke freeplay
Old Jul 20, 2008 | 07:51 PM
jnb5101's Avatar
jnb5101
Default diff side yoke freeplay
while changing the spring bolts to 8", i noticed (to my horror) that with the spring disconnected from the trailing arm, i could push the half shaft and the side yoke inward about 1/4" on both sides. the yokes don't seem to be protruding from the case when the half shafts are pulled outward. is this normal?
jeff
Old Jul 20, 2008 | 07:55 PM
mrvette's Avatar
mrvette
NO, you are at least way over TWICE over the absolute max allowed.....sorry 'bout that....
you end yokes and the cross shaft at a MINIMUM need replacing....
pull the rear outta there, and pull the rear cover off, and have a look, any questions, and you need show a pix or two.....
Old Jul 20, 2008 | 08:21 PM
jnb5101's Avatar
jnb5101
thanks for the reply. i had a feeling.....
jeff
To diff side yoke freeplay
