Yep, that's perfect. I usually order these 10 at a time because they make wiring relays so much cleaner. I know you would have to wait for it but they really do clean things up a lot and they are cheap.
I'm going to Advance during lunch and pickup a relay and hope they have the pigtail. If not I'll just wire it up without it. At this point the relay is the only thing keeping me from starting the new engine.
I might suggest that you wire a simple two position rocker switch inline with the relay ground so that you can both keep the pump off when doing work on the car, and have it for a security feature in the event of an accident or if someone tries to take your car.
