'77 Rear Wheel Bearings
Old Jul 22, 2008 | 11:17 PM
stevecstl's Avatar
stevecstl
Cruising
Default '77 Rear Wheel Bearings
My wheel bearings are showing some play. I would like to replace them but I am looking for some direction. It appears I should replace the whole trailing arm, and wheel assembly. Is this correct? Is it something that is reasonably replaceable or should I take it to the pros for replacement/repair? What else do I need to watch out for?
Old Jul 23, 2008 | 12:34 AM
Scott Marzahl's Avatar
Scott Marzahl
Can you fill out your profile so we know where you are from. If you plan on just R&R the trailing arm assemblies and having someone rebuild them, the biggest job will be removing the front pivot bolt. You may have to use a sawzal to get the bolt out. There are several good places to have them rebuilt.
