Need a Fuel Pump that Sucks
Old Jul 23, 2008 | 05:14 PM
CAJUN C4's Avatar
CAJUN C4
Default Need a Fuel Pump that Sucks
We need an Electric Fuel Pump that Draws fuel from the Tank instead of having to be gravity fed.Any Manufacturer of these types around?.?
We are currently using a Holley
It's for a friend of mine's 78'
Old Jul 23, 2008 | 07:07 PM
78Vette-SA's Avatar
78Vette-SA
You might want to look at the pump setup from an 82. Might even be a bolt-in for a 78 tank but I'm not sure. The only other thing is that it's for the Crossfire and would imagine if using a carb'ed app you would have lots of PSI to regulate.
Old Jul 24, 2008 | 01:50 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
HP or LP ??
My last TPI project I used a LP Delco pump to suck from the tank and to supply positive pressure to the HP Delco pump.
Yes I used 2 Electric pumps.
Old Jul 24, 2008 | 05:05 PM
Niart01's Avatar
Niart01
Default Electric Fuel Pump
Depending on how much CFM your carb needs, you can use an Edelbrock quiet pump. I have one in my 73 back by the fuel tank. It is set for 6.5 lbs. That is enough for a motor under 400 hp and about 750 CFM. It is quiet, and works just fine. They also have a pump that you can set the pressure on. Dont foget to use a relay with the pump. Jegs or Summit have both for about $75 for the pump, and $45 for the relay all wired up and ready to use.
To Need a Fuel Pump that Sucks
