Trailing arm bush removal
Old Jul 25, 2008 | 07:31 AM
Simmo's Avatar
Simmo
Default Trailing arm bush removal
Ive got my arms off, and drilled off the flared end of the bush. However there is still a metal washer in front of the rubber. Does this just pull off or do I need to drill it out too?
Old Jul 25, 2008 | 09:42 AM
GTR1999's Avatar
GTR1999
Once you get the flared sleeve out then you may find a air chisel under the hardened washer pops it out. Sometimes I have to use a cut wheel and cross cut the face and remove that washer. Then you get the rubber out and still have the steel bushing to remove.
Old Jul 29, 2008 | 08:49 PM
69small block's Avatar
69small block
where is the best place to buy the parts required to rebuild t arms thanks Id like to do this myself I hear you have a good write up about this could you possibly pm it to me
Old Jul 29, 2008 | 08:59 PM
...Roger...'s Avatar
...Roger...
I think this is it.
http://forums.corvetteforum.com/show....php?t=1229686
Old Jul 30, 2008 | 08:50 AM
GTR1999's Avatar
GTR1999
I sent you a PM with info
To Trailing arm bush removal
