Another PCV question
Old Jul 26, 2008 | 06:51 AM
Shurshot's Avatar
Shurshot
Default Another PCV question
If you do not have a baffle on the PCV side nor room for one can I place sort of filter element in a breather cap with a PCV installed in it (such as billet specialties offers) to take the place of the baffle in the valve cover?
Last year I ran the cap with the PCV routed to a vacuum inlet in the carb base but without any baffler nor filter. However when I tore the heads down down the valves were covered in crud after only 2000 miles.
I figured I was sucking oil into the motor and have considered installing a vacuum catch can or pump of some sort to keep from allowing oil into the intake
Doug
Old Jul 26, 2008 | 09:04 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
A catch can should work, they are a common install on the newer vettes for this purpose.
Neal
Old Jul 26, 2008 | 10:37 AM
Shurshot's Avatar
Shurshot
Neal
Thanks Neal
Old Jul 26, 2008 | 03:14 PM
Surfer69's Avatar
Surfer69
I noticed on my new eninge oil build up from the PCV all over the place and also causing slight run-on. After I installed two new K&N breathers, no more run on and I'm sure no oily build up either.
To Another PCV question
