New Gas Tank Prep?
Old Jul 27, 2008 | 10:24 PM
willem wallace's Avatar
willem wallace
Default New Gas Tank Prep?
Should I do anything to the new gas tank I am putting onto the frame of my roadster, before installation? Is any type of paint or rustproofing required? Any info is appreciated.
Old Jul 28, 2008 | 06:53 AM
willem wallace
ttt
Old Jul 28, 2008 | 07:10 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would talk to the manufacturer about this for recommendations.
Old Jul 28, 2008 | 08:12 AM
bashcraft's Avatar
bashcraft
The tank is galvanized. There's no reason to do anything to it.
Old Jul 28, 2008 | 09:10 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I put new Quanta tanks in both my 61 and my 65. No prep and they still look fine.
Old Jul 28, 2008 | 12:20 PM
68/70Vette's Avatar
68/70Vette
I've installed two new Quanta tanks; one in the 68 and the other in the 70.
First I washed the outside down with lacquer thinner. The tanks are covered in a thin film of wax that acts as lubricant during the pressing process. The tanks are tin plated (I think it's tin). Then I paint them with Eastwoods Tank Tone. It's a metallic zinc paint. I do this to give the outside surface a little extra corrosion protection. As you can see, the original tanks with the same coating as Qaunta's (I think) will corrode after years. So I give'm a little extra protection.
Also, at the rear of the tank, look at the flanges (where the two halves are mated) you can see there's an indentation for the straps. I've found it helps to indent the flange to effective decrease the effective circumfrance of the tank to create extra tolerance for the straps. I use a 2X4 and a hammer to bend them down a little more.
The straps (because they are repro?) seem a little bit short. They may not fit under the top edge of the frame far enough for the strap tightening bolt to fit from under the bottom edge of the frame. (Had no problem with the 68, this problem occurred with the 70) I screwed some 3/4 inch 3/8 bolts in the strap mounting bolt holes and then used a drift to hammer the bolts and force the strap deeper into the frame so that the proper 3/8 bolts could be screwed into the strap mounting holes.
To New Gas Tank Prep?
