L82 Bottom End.
Anything special about the rotating assembly that's different from an L48?
Did all L82s come with the splash shield bolted over the tops of the mains and did all L82s have the extra baffling in the oil pan?
There were major differences in the roatting assemblies between L-48 and L-82.
- All L-82's were 4 bolt main with forged crank, pink rods (rods shotpeened for strength) and forged flattop pistons. Good basis for a buildup.
- The L-48's had cast crank, cast dished pistons, and normal rods. Some L-48's got a 4 bolt block but only when they ran out of 2 bolts. Basically standard GM car engine.
All L-82 bottom ends have the forged flat tops, upgraded rods, steel crankshaft, 4 bolt mains, extended main cap studs and the windage tray. The engine suffix stamp would indicate the L-82 so that external ID method is about as good as it gets. Second only to pulling the pan off.
An L-48 could be found with a 4 bolt main but it would be very rare. There would have to be a shortage of 2-bolt blocks in the engine assembly plant and some spare 4-bolt blocks available. They both use the same casting but they are machined differently. L-48 4-bolt main possible? yes, likely? not very.
-Mark.
he was also told, but couldn't confirm, that when St. Louis would run low on L-48s, it's possible some L-82s were installed, while all paper-work read L-48, again, to keep production fluid.
My '79 Z28 came with an engine designated LM-1, but I believe it is identical to the L-48 in almost all aspects
Just to add to the above: L-82 flat tops were 6cc relief volume, and mine cmae from teh factory with .015" thick steel shim head gaskets to give a perfect .040 quench.
