Crossfire timing problem
Old Jul 30, 2008 | 11:29 AM
rsvette82's Avatar
rsvette82
Default Crossfire timing problem
I am still trying to fire up my rebuilt crossfire motor and have ran into another problem. When I put in the distributor I had the rotor pointed towards #1 and when I tried to start it I had to rotate the cap counter clockwise 1/4 of a turn just to get it to fire but it still will not start. I am fairly sure that I set the distributor with #1 at top dead center on the compression stroke. What does a engine act like if you have it off by 180? Any ideas would definently be a help.
Old Jul 30, 2008 | 11:31 AM
V-Twin's Avatar
V-Twin
180 off, simply won't start, won't do anything.
There's a "1" imprinted on the module!
Old Jul 30, 2008 | 11:44 AM
rsvette82's Avatar
rsvette82
I guess I must be a little slow today - what does the "1" stand for on the module?
Old Jul 30, 2008 | 12:12 PM
V-Twin's Avatar
V-Twin
#1 spark plug tower, so if you aim the rotor there all will be fine
Old Jul 30, 2008 | 12:21 PM
rsvette82's Avatar
rsvette82
Great. I will give it a try tonight. Thanks
Old Jul 30, 2008 | 02:17 PM
hugie82's Avatar
hugie82
When you drop in the dist., clock it counter clockwise an inch so when the gears mesh the dist. is right on.
Old Jul 30, 2008 | 04:20 PM
V-Twin's Avatar
V-Twin
Or just drop it in where you want it and bump the starter, it will drop right in place.
To Crossfire timing problem
