Old Aug 3, 2008 | 04:48 PM
DARROW's Avatar
DARROW
Default 454
What is the difference between the mark 4, 454 and the mark 5, short block.
Old Aug 3, 2008 | 06:52 PM
ZL1powr's Avatar
ZL1powr
Mark 5 has no provision for a mechanical fuel pump, no provision for a clutch crank ball, main oil passage is along cam instead of along the oil pan rail and the water passage interface with the heads is different (unless you use a special head gasket Mark 4 heads may leak on a Mark 5 but aftermarket heads work fine).
