C4 Fibration - Puzzled
Old Aug 3, 2008 | 10:21 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default C4 Vibration - Puzzled
My 86 goes down smooth asphalt pavement at speeds 35-55 and I feel a vibration of some sort.
I just installed brand new tires thinking that the old ones were bad! That helped some but I still feel a vibration in the car.
Where should I look next? I'm starting to think this is a bent wheel or out of balance drive line or ??
Wish I had a known good set of wheel and tire to try, so I could sort this out.
ADMIN HELP: Please move to "C4 - General Discussion"
Any ideas? Thanks!
Old Aug 3, 2008 | 10:57 PM
SIXFOOTER's Avatar
SIXFOOTER
Well, to start its Vibration with a V. Next, did you watch them to make sure the new tires ballanced out correctly with little or no runout?
Next thing to look at would be U-Joints.
Oh and the C4 section might be more help
Old Aug 4, 2008 | 12:52 AM
PatG's Avatar
PatG
I can attest to a u-joint causing a vibration. I had a barely noticeable vibration at ~45 MPH for years and finally solved it when I found a u-joint cap on the drive shaft was just a bit tight. I disassembled, re-greased and put it back together correctly and the vibration was gone.
Now, if you could describe the vibration a bit more there may be other suggestions. Is your vibration just noticeable or is the steering wheel shaking?
Old Aug 4, 2008 | 07:56 AM
tdf's Avatar
tdf
St. Jude Donor '11
Default Vibration - Not Just in the Steering Wheel
Sorry for the brain fart "Fibration".....LoL
This vibration seems to be felt in the whole car.
Are you guys speaking of the U-Joints in the drive shaft, axles or both? Wouldn't there be noise (Clunking) usually associated with U-Joint failure?
Thanks for the help.
Old Aug 4, 2008 | 05:43 PM
SIXFOOTER's Avatar
SIXFOOTER
You need to look at the whole drive line, from the flex plate/flywheel all the way back.
Also look for a busted motormount
Old Aug 4, 2008 | 06:04 PM
r44s's Avatar
r44s
Had a vibration in my 73 between 57-63 MPH after many trials and errors replaced the rear spring raising the rear and the vibration quit. Not only stopped the vibration, but it looks better.
To C4 Fibration - Puzzled
