How to Install this part?
Old Aug 4, 2008 | 09:45 PM
DO2G's Avatar
DO2G
Default How to Install this part?
I need to install this center exhaust support for my dual exhaust. See the link below.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050Q
How does this part install?
Old Aug 4, 2008 | 09:55 PM
TopGunn's Avatar
TopGunn
It goes between the transmissioin tailshaft and the mount, the ears face rearward. The pipes tuck under it and are secured to it with muffler clamps.
Old Aug 4, 2008 | 09:56 PM
wjsullivan's Avatar
wjsullivan
The bracket mounts to the bottom of the transmission. Then u-clamps hold the exhaust to it.
Old Aug 4, 2008 | 10:02 PM
DO2G's Avatar
DO2G
does it just bolt right on? or do alot of parts need removed to be installed?
Old Aug 4, 2008 | 10:08 PM
TopGunn's Avatar
TopGunn
You'll have to unbolt the tailshaft from the mount and raise it slightly to get it in but it should go.
Old Aug 4, 2008 | 10:27 PM
DO2G's Avatar
DO2G
Are the tailshaft bolts easily accessible from under the car? Can this be done with ramps or jack stands?
Thanks for all your help.
PS> TopGunn do you ever come down to the New Haven area for cruise nights or shows?
Old Aug 4, 2008 | 11:03 PM
TopGunn's Avatar
TopGunn
Yes you can get to them easily. I tried to take a picture for you but can't get a good shot with the car on the ground. Either ramps or jackstands will do the trick, you just need to get room enough to work, the higher the better for comfort. You may have to pull the driveshaft but not sure. I installed my mount before the shaft was in place.
I was going to ask where you were in CT., no I don't get down that way too much, I'm about 3 miles from the MA line so it's a trip. I went to Guilford to Moroso show a few weeks ago......did you?
Pic below:
Old Aug 4, 2008 | 11:35 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Another pic for ya. I found it easier to unbolt the mount, jack up the trans just enought to REMOVE the mount, and then slip the hanger and mount back in together.
Old Aug 5, 2008 | 07:52 AM
DO2G's Avatar
DO2G
[QUOTE=TopGunn;1566589776]Yes you can get to them easily. I tried to take a picture for you but can't get a good shot with the car on the ground. Either ramps or jackstands will do the trick, you just need to get room enough to work, the higher the better for comfort. You may have to pull the driveshaft but not sure. I installed my mount before the shaft was in place.
Cheshire...I was on vacation and missed the Moroso show, but the pictures looked great.
Old Aug 5, 2008 | 07:53 AM
DO2G's Avatar
DO2G
You always come through for me...Thank you
Old Aug 5, 2008 | 08:03 AM
...Roger...'s Avatar
...Roger...
Your probably already aware but if you are using ramps be sure and put a block behind your rear wheels.Working in this area could kick the trans into neutral.
To How to Install this part?
