Buying a Vacuum Gauge?
Old Aug 7, 2008 | 01:03 PM
slash19's Avatar
slash19
1st Gear
Default Buying a Vacuum Gauge?
Anyone have any recommendations on a good quality, low cost vacuum gauge for a stock 73? Just replaced the entire headlight system (actuators all the way back to the switch) and now I need to troubleshoot the system. Thanks.
Old Aug 7, 2008 | 01:35 PM
SH-60B's Avatar
SH-60B
For most things you can use one for you don't really need to know how much vacuum you have, just if it's more vac or less vac than what you're comparing it to. How many inches you have is helpfull in identifying cam characteristics, but for troubleshooting I think just about any gage would do the job.
Old Aug 7, 2008 | 01:52 PM
BB427's Avatar
BB427
I was told by a old timer a few days ago the simplest way to check for a vacume on the older vette a plumbers propane tank works best. Just turn the tank on NO Flame and run it along your hoses if you are sucking air at any point you idle will rise it. as all vacume is shared. I haven't tested it myself but the guy that told me owns a few vette 62 -67 aqnd a early 70's
Old Aug 7, 2008 | 02:37 PM
...Roger...'s Avatar
...Roger...
If your going to troubleshoot vacuum just buy a vacuum gun like a Mighty Mite.
Old Aug 7, 2008 | 04:59 PM
GaryS's Avatar
GaryS
Go to Sears tool department section and buy their vacuum gauge. Lots of different nipples and a very large, easy to read gauge. Fwiw, I own that and a Mity Vac but prefer the simple gauge when doing tuneups. Around $35 or so, iirc.
Gary
Old Aug 7, 2008 | 08:08 PM
DC3's Avatar
DC3
For troubleshooting the headlight system, the Mity Vac is a good tool. I used one to determine I have a bad headlight actuator rod seal on the drivers side.
A regular vacuum gauge is a valuable tool for engine tuning and testing.
One option is to spend a little more and get the metal bodied Mity Vac (or Sears equivalent). The gauge on this one is much better than the gauge on the plastic one and is sufficient for doing the engine tune and test thing so you could get by with one tool.
The advantage of a true vacuum gauge for tuning is that it most likely will also come with the ability to measure pressure including fuel pressure.
Just don't do what I did. I went to Sears and plucked the first Actron vacuum gauge off the shelf and bought it without looking at it closely. That gauge showed my engine was only producing 9-10 inches of vacuum which is too low and had me chasing that gremlin for a month. Turns out, the gauge was bad. Had I bothered to look closely and compare several gauges I would have noticed the needle was way off on the one I purchased. Live and learn.
Hope this helps.
DC
Old Aug 7, 2008 | 08:18 PM
Steve439's Avatar
Steve439
Well there's a great real world experience!
I'm just about ready to tune my newly fired up motor.
I think I'll check my cheapy years-old vacuum gauge with my Mity-Vac before I start...
Old Aug 7, 2008 | 08:27 PM
DC3's Avatar
DC3
That's how I finally figured out my new gauge was bad.
DC
Old Aug 7, 2008 | 10:22 PM
Vampyre's Avatar
Vampyre
How do you test the system, at what points?
What should the vaccum guage read>?
Old Aug 8, 2008 | 01:57 AM
martinsw's Avatar
martinsw
I installed a 2-1/4" VDO vacuum gauge in my center console - lets me know when a connector comes off, headlight seal fails, etc. IMO with these cars the question is not IF your vacuum system is going to have a leak, but WHEN (and repeat).
Also helps drive like a 'little old lady' and get the most MPG out of todays high price gas - NOT.
Old Aug 8, 2008 | 05:15 AM
SH-60B's Avatar
SH-60B
It could leak anywhere. If you can't see anything obvious, start at the manifold and work your way to the headlight actuators by pulling off each connection and testing each component, switch, check valve and hose as you go. As far as a reading, you should be able to pull as much vacuum, and hold it, as the mityvac tool can give you.
Old Aug 8, 2008 | 09:30 AM
TFitz's Avatar
TFitz
go to NAPPA. thats where I got mine. took care of all vacum testing. about $40
Old Aug 8, 2008 | 09:35 AM
Vampyre's Avatar
Vampyre
SH-60B thanks for the info....
This is the one I have... never used it...
http://www.harborfreight.com/cpi/cta...emnumber=92474
Is it any good or should I just get the mityvac?
Old Aug 9, 2008 | 06:14 AM
SH-60B's Avatar
SH-60B
Use the one you have. I have a mityvac and the two are virtually the same.
To Buying a Vacuum Gauge?
