AC brackets
Old Aug 8, 2008 | 02:42 PM
glo's Avatar
glo
Default AC brackets
Have 77 350, need pic of AC brackets I have the round compressor not the long one. Thinking any bracket off a 350 will work? Can not find salvage yard that will let me walk thru and look and purchase brackets.
or I can change compressor to the long one,what ever works will need air here in Florida.
Old Aug 8, 2008 | 06:28 PM
markdtn's Avatar
markdtn
You need Corvette specific brackets. 76L-82 should interchange. The water pump on a C3 is short, similar to 55-68 passenger. Try Ebay, swap meet, Corvette used parts vendor. May try Brad at Brads Corvettes in Ft Lauderdale or Corvettemack on Ebay.
Old Aug 9, 2008 | 06:39 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Actually, if the water pump on a C3 has a 3/4 inch shaft, it is actually about a 1/10 of an inch longer that the earlier "short" water pumps which have 5/8 inch shafts. It does make a difference for belt alignment.
Old Aug 10, 2008 | 12:14 AM
speedreed8's Avatar
speedreed8
you have to have these
http://www.zip-products.com/Zip/dept...F8951A14A1DC13
Old Aug 10, 2008 | 02:13 PM
glo's Avatar
glo
To AC brackets
