Belt tension
Old Aug 8, 2008 | 07:59 PM
BassCat's Avatar
BassCat
Default Belt tension
I completely replaced the A/C unit in my '77 last week and the new system works great. It's still the same setup as the original, just with a new compressor, dryer, etc. The only thing of concern I have noticed is that when I have the A/C turned on, the belt has a good bit of slop in it on the lower side between the A/C compressor and the crankshaft pulley. I loosened the compressor bolts and tightened the belt some using a short crow bar for leverage. There's not nearly as much slop as before and the belt has roughly 1/2 inch of play in it now. Does this sound about right? I just don't want to overtighten it and start causing problems elsewhere, such as water pump bearings. Is some slop in the belt normal at idle with the A/C on??? What do the experts say??
Kenny
Old Aug 9, 2008 | 08:30 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
1/2" of flex is about what I have always used for belt tension. As long as you don't have so much slop that it's going to jump the pulley. You always walk a fine line between too loose and too tight and stressing bearings and water pumps. About 1/2" or slightly less has always worked for me.
Old Aug 9, 2008 | 09:27 AM
AimHigh's Avatar
AimHigh
To Belt tension
