lumination lights don"t work
Old Aug 10, 2008 | 06:53 PM
car71's Avatar
car71
Default lumination lights don"t work
hi 1971 vette lumination lights won"t work in center bezel in less a put 12 volts to the fuse. okay are they wired up thew the head light switch, the dimmer part of it,need help thanks
Old Aug 10, 2008 | 06:59 PM
...Roger...'s Avatar
...Roger...
The fuse is fed from the headlight switch.So your problem is up there...probably the rheostat.(spelling)
Old Aug 10, 2008 | 07:07 PM
car71's Avatar
car71
Is the rheostat part of the head light switch if so i need a new switch.thanks
Old Aug 11, 2008 | 08:10 AM
GaryS's Avatar
GaryS
Yes. You can replace the entire switch and the rheostat is part of it. If you have never replaced the headlight switch, you might want to play around with one to see how the **** releases first, since you will be doing this by feel.
Gary
Old Aug 11, 2008 | 10:45 AM
71406's Avatar
71406
Your original post states the lights dont work in the center bezel (fuel, temp, clock, etc). Can we assume they work for other parts of the dash? Like the speedo and tach? If yes, you might have a ground problem in the center bezel.
Old Aug 11, 2008 | 02:58 PM
car71's Avatar
car71
good question paul, didn"t check to see if the dash lights work, I will do that today. thanks
To lumination lights don"t work
