Clutch Linkage Help!!
Old Aug 10, 2008 | 08:27 PM
Kim72's Avatar
Kim72
Default Clutch Linkage Help!!
I've been working my way through installing a new Centerforce Dual Friction clutch. It's in a Lakewood scatter sheild which I have always had. I did all the measurements as per the install instructions (yes, I actually read the instructions). Problem: the throw out arm (new) is hitting big time up against the floor board fiberglass when engaging the clutch. It was always close but now it's crunching glass real bad. Is there a cure for this clutch linkage geometry?? Pivot ball, throwout bearing?? Please don't tell me I have to pull the tranny again!! I'll go crazy!!
Old Aug 10, 2008 | 08:34 PM
howarsc's Avatar
howarsc
I am having the same issues and other with a custom clutch. You can do an adjustable fork pivot ball or one that is just 1.75" long instead of the factory 1.5" or 1.25". The other option is a long style throwout bearing. I have done the pivot ball but due to another issue I need the throwout bearing instead.
Either way it comes out or at least pulled back.
Old Aug 10, 2008 | 08:37 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
we need pictures to help you.. you do not have orgnal configuration.
Old Aug 10, 2008 | 08:45 PM
howarsc's Avatar
howarsc
I did have the same floor pan clearance problem with the same clutch you have and the pivot ball alone fixed it.
Old Aug 11, 2008 | 10:55 AM
68 Blues's Avatar
68 Blues
I went throught the same problems when I installed a centerforce clutch kit. I found that the adjustable ball helped, but didn't quite take care of the problem. I ended up buying an adjustable throw out bearing from McLeod. It basically presses together and has two or three "rings" that you can switch or stack. If I remember correctly, the one it came with did the trick.
Old Aug 11, 2008 | 06:11 PM
SteveG75's Avatar
SteveG75
Corvettes do not use the same clutch fork (throwout arm) as any other GM car due to the floor pan. You need to use the corvette specific part.
Part CL-101, $66.95 at Zip
Note the biger curve on the Corvette part vice the standard GM part.
PS: I have over 10,000 miles on my CF Dual Friction and the only thing I had to swap was the pivot ball.
To Clutch Linkage Help!!
