'82 CE pin stripes
Old Jan 1, 2002 | 06:04 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default '82 CE pin stripes
A friend has just had a mishap with his new '82 CE and needs some info.
Is the pin stripe a decal or painted? Thanks much for any info.
Old Jan 1, 2002 | 06:16 AM
78pace's Avatar
78pace
Default Re: '82 CE pin stripes (65Z01)
they are decals that can be bought in a kit from several vendors
the problem is you have to by the hole kit from say ecklers for about 1500.00
for the ce I have seen decals for my pace car on a web site where you can buy them seperate but forget the site i will look for it
Old Jan 1, 2002 | 06:19 AM
78pace's Avatar
78pace
check out http://www.stencilsandstripes.com but still very very expensive good luck
Old Jan 1, 2002 | 06:58 AM
65Z01's Avatar
65Z01
Default Re: '82 CE pin stripes (78pace)
78pace, thanks much for the direction; I'll relay the info.
Best of the new year to you.
Old Jan 1, 2002 | 01:41 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You can buy just the pin strips (all or just the ones you need) here: http://www.musclecardecals.net/gm/1982cvt.htm
A lot less expensive. :D
[Modified by gq82, 12:48 PM 1/1/2002]
Old Jan 1, 2002 | 01:46 PM
1yy07's Avatar
1yy07
It is a decal. :D
Old Jan 1, 2002 | 04:18 PM
82dukman's Avatar
82dukman
Default Re: '82 CE pin stripes (1yy07)
I have an 82 CE too. Saw this on the Collectors Edition forum for $319 for the whole car It has every stripe and fade decal for the whole car. Check it out here http://www.phoenixgraphix.com/gm/1982cvt.htm
You can also just buy whatever stripes you need
Hope this helps :seeya
[Modified by 82dukman, 3:22 PM 1/1/2002]
To '82 CE pin stripes
