When did the SS calipers appeared?
Old Aug 12, 2008 | 05:08 AM
bioposi's Avatar
bioposi
Default When did the SS calipers appeared?
Hi everyone,
I am in the process of rebuilding my brake calipers on my 1977. The rear right caliper is not of the type of the three others (SSBC instead of Delco Moraine). As I prefer to have a complete set of Delco Moraine, I found a vendor near me in France that sells four DM calipers out of a 1965 Corvette that has unfortunately crashed.
Does anyone knows when the Stainless Sleeves have appeared in the 1968-1982 period, as I would ensure that my vendor's set is of the SS type (and no, he is not going to open the calipers to check this out )
Thanks in advance.
A '77 is waiting to get back on the road.
Bio/
Old Aug 12, 2008 | 07:18 AM
Mike Ward's Avatar
Mike Ward
These were never factory issue, only aftermarket. I know the vendors were selling them in the early 80s, possibly prior to that.
Old Aug 12, 2008 | 07:51 AM
noonie's Avatar
noonie
First I saw were around 75 and you sent yours in to be done. Don't remember where.
Old Aug 12, 2008 | 08:56 AM
bioposi's Avatar
bioposi
Thank you both for your answers.
Knowing now that only aftermarket product were stainless sleeved, I'll check if the vendor's car was genuine or not (I don't think so). This leave me a good chance to find the part I need.
Thanks again for your valuable support.
Old Aug 12, 2008 | 09:25 AM
wombvette's Avatar
wombvette
Those 65 calipers are not really the same as your 77, if they are original. They had the two piece pistons and the different castings. They may have been changed, but if they are originals, you will have to send them out for rebuild anyway. If they have been changed you might have a chance.
Old Aug 12, 2008 | 09:33 AM
bioposi's Avatar
bioposi
The vendor gave me the following reference stamped on the calipers. They all are from Delco Moraine:
front left: 5473786 and 5452270
front right: 5473785 and 5470796
rear left: 1012 and 1013
rear right: 5473808 and 5452284
I don't know that much about these references. Any chance these are modern ones, stainless steel type?
Thx.
Old Aug 12, 2008 | 11:59 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
No SS calipers ever came from the factory, but they are a worthwhile improvement as the originals tend to develop pits in the cylinder walls. FYI, the factory original part numbers for your '77 are as follows:
Front calipers, 2621203 inner right, 2621202 or 2621204 inner left, 2621206 outer both. Rear calipers, 2621204 inner left, 2621205 inner right, 2621207 outer left, 2621208 outer right.
As well as being used for all C3's from '76-'82, for non-HD brake applications, 2621202, 2621203 & 2621206 were used from '65-'75, and 2621204, 2621205, 2621207 & 2621208 from '67-'75. The HD brake option ended in '75.
The 54##### numbers you have are Delco Moraine replacement casting numbers, which I don't believe come SS lined although SSBC and VB&P modify and sell these new as such. Don't know what 1012 or 1013 refer to as far as a caliper goes.
Hope that helps.
To When did the SS calipers appeared?
