Shark Bite? rear coil setup???
Old Aug 14, 2008 | 09:52 AM
sly vette's Avatar
sly vette
Default Shark Bite? rear coil setup???
I know that I only stop here a few times a week ,but as of this time I have yet to see anything regarding the new rear coil over spring set up that was offered earlier this year.
I was wondering If any one has installed this package and what they thought of it.
Mark
Old Aug 15, 2008 | 01:08 PM
Skunkvette's Avatar
Skunkvette
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Mark,
I installed the Shark Bite setup on my 72, finished up a few weeks ago and posted a review when the GP was a sticky.
Overall I was pleased with the set up although I thnk it still needs some "tweaks" to be a true bolt on kit. My application was a little different as I run 12 bolt rear.
Now have about 300 miles on the kit and really like the ride, the look and freedom to adjust as necessary, the real test will be on the track.
Old Aug 16, 2008 | 10:41 AM
sly vette's Avatar
sly vette
Originally Posted by Skunkvette
Mark,
May I ask what was the GP price, and do you feel it was a good investment at this point??
Mark
Old Aug 16, 2008 | 12:30 PM
Skunkvette's Avatar
Skunkvette
Mark
I bought the double adjustable with full polish, GP price was a tad under $1,800.
As far as hindsight on the purchase, I had tried to install the Van Steel rear coil over package and had clearance conflicts with the over sized half shaft that I wanted to run, and ended up trashing that.
The Shark Bite put the coils behind the rear, and clear of the half shafts, so it was a plus on the engineering side, and the "look" is sharp.
I would advise to be careful with the trailing arms you use with the Shark Bite, the Van Steel double offsets I originally had on my car did not work with the Shark Bite attachment bracket.
Old Aug 16, 2008 | 12:58 PM
ctk30's Avatar
ctk30
IMHO it's more for looks than performance
Old Aug 16, 2008 | 04:40 PM
Skunkvette's Avatar
Skunkvette
Agreed, but if you have a clearance issue then it can be of benifit to move the coil overs behind the pumpkin.
Old Aug 16, 2008 | 06:04 PM
sly vette's Avatar
sly vette
Is there an improvement over the ride that we experiance with the traditional transverse spring??
Mark
Old Aug 16, 2008 | 06:28 PM
Skunkvette's Avatar
Skunkvette
Mark
Large improvement, and the added bonus of adjustability.
I upgraded both the front and rear suspensions at the same time and now the car rides more like a C5 than a C3. Car feels more stable, tracks better and corners flatter.
Still waiting for some track time to start tuning.
Old Aug 16, 2008 | 10:39 PM
sly vette's Avatar
sly vette
Please post your feelings on the system once you get some track time in. I will look forward to your results.
Mark
Old Aug 17, 2008 | 12:05 AM
eastltd's Avatar
eastltd
That's a sweet set-up you've got there Shunkvette. I wish I would have found it before buying my composite spring combo.
To Shark Bite? rear coil setup???
