Seems the center hole is too narrow
Clutch alignment tool was hard to install and it didn't slide after centering the clutch so I have to put everything apart again.
I'm afraid I won't be able to reinstall the trans as the diameter shaft is about the same as the tool...
Can I use my dremel to slightly enlarge that hole or should I get a new bronze pilot bushing ?
Did the Kevlar bushing slip over the trans snout before installing it in the crank?
If so, then the outside diameter was too big and the bushing compressed when installed. It will probably be difficult to remove without damage to the bushing, but at the cost of bushings theese days, worth the try.
I just took some quick measurements of an old Muncie snout and a new GM bronze bushing:
Snout - .588" (14.94mm)
Bush - .592" (15.04mm) inside diameter
Bush - 1.094" (27.79mm) outside diameter
If you can get it out without damage perhaps a maching shop could run a 15mm reamer through it. If the outside diameter is too large, it could be turned smaller in a lathe.
It can easily be removed without damage using the dowel/grease method.
But make sure you dont drive the bearing in too far...on some of the cranks inside is a lip and when you go in and over the lip the ID of the bushing becomes smaller.I always leave the bushing out about 1/4"
The depth of the cavity should be about .800 because thats usually how long the bushing is but I have been running into cranks that are only .650 deep.
Thanks guys
I made a newbie mistake by not test fitting on the trans snout before installing
Maybe I've driven it too far.
Those damn instructions said to install it flush and glue the outside with strong anti-seize sealant !
I'm wondering if the dowel/grease method will work on this one
Forgot to mention I'm using a Scat crank.
Thanks guys
I would also recommend a test install of the transmission "without" the clutch.Once you have the trans. in place put the trans. in any gear and see if you can turn the output shaft.If it turns freely then the input shaft is not binding in the pilot bushing.It will take less than 30 min. and it will be one thing you dont have to worry about if you have other issues.
Thanks guys
The dowel/grease WILL work if you do it correctly. When the dowel (wood/brass/steel - whatever) is a close (but not tight) fit and hit hard and sharp, there is an incredible amount of hydraulic pressure generated behind it.
