Help with an electrical problem
My questoin is ..... from the relay to the alternator does the Relay Positive wire first go into and then out of the back of the fuse block (I'm assuming it is fused?), and then connect to the alternator, or am I completely off base?
Could someone take a picture of a stock setup of the 81 or 80 for that matter I assume they are the same, and point out the connections that are on the alternator.
I got the charging problem fixed - the battery now has a return from the alternator. But in the process I may have disconnected a wire that was connected to the alternator because I couldn't figure out what it was for.
I bought a new relay but I don't think I need it - cause I remember taping up a red wire that seemed to come from nowhere. So now I am figureing that it must have been the high speed blower relay wire?
I don't want to make a random connection here for fear of shorting out something.
I'd appreciate some help here.
what is the symptom you are trying to fix ?
there is more than 1 positive wire,
so it makes it difficult to advise on your description.
But there now is a big difference between 3 and 4 position on the blower switch now.
