Halp! Clutch disc installation
Old Aug 17, 2008 | 03:59 PM
Paul Workman's Avatar
Paul Workman
Default Halp! Clutch disc installation
On a 69 350 w/ M21(?) which side of the clutch friction disc goes to the flywheel - one side has a protrusion on the spline, and one side doesn't, and I can't seem to remember (crs disease, I recon!)
Thanks in advance!
P.
Old Aug 17, 2008 | 04:24 PM
Ironcross's Avatar
Ironcross
The springs are recessed on the flywheel side of the disc and the hub will face the pressure plate {transmission side}. Try it against the flywheel and it should become apparent.....
Old Aug 17, 2008 | 05:25 PM
A88FXRS's Avatar
A88FXRS
Should be stamped on disc. Flywheel side
Old Aug 18, 2008 | 03:45 AM
Paul Workman
Default Thanks y'all!
Yeah, it was obvious, once I tried it either way. (My last clutch job was on a '95 LT1 Vette (last summer, actually) with the ZF6 and on that one the disc could be flipped, as I recall.) Anywayz, thanks for the quick response! Now if I could just stab the trans back into the pilot bushing...(being a pain - alignment tool not withstanding).
P.
Old Aug 18, 2008 | 12:16 PM
TopGunn's Avatar
TopGunn
P.
I made up some alignment studs by cutting off the heads of a couple of transmission bolts and grinding the ends like a bullet. Insert them in the bellhousing and make them long enough so the tranny will hang on them before it touches the pilot. Then you can push the transmissiion in knowing it's pretty straight. Good luck with it
To Halp! Clutch disc installation
