Need Vacuum Help
Old Aug 17, 2008 | 07:27 PM
RB04ZO6's Avatar
RB04ZO6
Default Need Vacuum Help
I am having a problem with my '68 Roadster headlight doors and wiper door. Both were working perfectly but both quit working at the same time. When they quit working the wiper override light came on and stays on.
I have 13 inches of mercury at the intake manifold all the way to the inlet to the reservoir. At the discharge of the vacuum reservoir I only have 5 inches of mercury, it takes the gauge several seconds to get up to 5. I assume that if the reservoir has a leak I should be able to by-pass it and the system should work. I connected the vacuum line from the intake manifold directly to the tee
immediatly downstream from the reservoir, this should by-pass the
reservoir, but neither system works.
I would appreciate some help on this. Does anybody have any insight on what would make both systems cease to operate?
Thanks in advance!
Old Aug 17, 2008 | 08:15 PM
SmokinBBC's Avatar
SmokinBBC
Hose off at the override switch under the dash? Bad override switch?
Old Aug 17, 2008 | 08:31 PM
...Roger...'s Avatar
...Roger...
68 has a wiper override light....interesting...didnt know that.
Old Aug 17, 2008 | 10:40 PM
rappellmaster87's Avatar
rappellmaster87
Corvette America or Ecklers Corvette has great troubleshooting manual for your problem. I bought a copy, read it a few times and fully understood the science behind how the vacuum system works. My wiper door would not go down and would only stay up. I follow the vacuum schematic system and it led me to the override switch under the dash right below the tach gage. After I replaced it, everything works like a charm. SmokinBBC is correct!
Old Aug 18, 2008 | 08:14 AM
RB04ZO6's Avatar
RB04ZO6
I will check out the override switch. Do you think it would affect the headlight doors also?
Old Aug 18, 2008 | 08:52 AM
...Roger...
Both systems are connected(headlights and wipers)...thats what makes it difficult to figure out sometimes.each have 2 parts....the large hose vac. part that moves the doors and the smaller hose part that "TELLS" the large part "what" to do.
To Need Vacuum Help
