Holley vs Q-Jet
Old Aug 19, 2008 | 04:05 PM
Petes73's Avatar
Petes73
Default Holley vs Q-Jet
Does anyone know the height of the 4150 and the height of a Q-Jet? I ordered a 670 street avenger and was wondering about clearance with the stock air filter.
Old Aug 19, 2008 | 04:26 PM
Oldguard 7's Avatar
Oldguard 7
No I do not, but the 73 has a high-rise stock hood and you should have no clearance problems as is. If you are in doubt, you can purchase a drop base air cleaner from summitt, jegs, etc.
Old Aug 19, 2008 | 04:59 PM
speedreed8's Avatar
speedreed8
you probably know this, but the q-jet has a spreadbore base and the avenger has a square bore base. if you're putting it on the stock intake it probably wont fit. just fyi..
Old Aug 19, 2008 | 05:02 PM
Petes73's Avatar
Petes73
Yep I already have the vortec heads, headers, new cam and performer intake. This was the last step.
Old Aug 19, 2008 | 05:59 PM
speedreed8's Avatar
speedreed8
thats what i thought, sounds like a sweet setup, carry on......
Old Aug 19, 2008 | 06:15 PM
SteveG75's Avatar
SteveG75
Stock aircleaner will not clear the bowls on the Holley.
Old Aug 19, 2008 | 06:54 PM
Petes73's Avatar
Petes73
Thanks I was hoping to keep the cold air , but it looks like a drop base then.
Old Aug 21, 2008 | 04:47 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I have measured the height of the Holley 4150/4160 carbs from bottom of base plate to air cleaner contact ledge, and then compared that measurement to the Quadrajet carbs (because the Q-Jets looked taller). Both were the same.
Old Aug 22, 2008 | 09:16 AM
Petes73's Avatar
Petes73
Thanks for the info. the Holley was delivered last night. Looks like I will need a new air cleaner as stated. The float adjusters are hitting the stock one.
To Holley vs Q-Jet
