502 swap, hood clearance ?
Old Aug 19, 2008 | 10:48 PM
JUST TRY 03's Avatar
JUST TRY 03
Default 502 swap, hood clearance ?
i have a 1978 that i just put a GM performance 502 in, problem is the intake manifold sits just under the fender line, i wanted to get a l88 style hood but that wont clear the carb and air cleaner so my only other option is a 4 inch cowl hood which i am undecided about..so does anyone know if someone makes a hood tall enough to clear everything
Old Aug 19, 2008 | 11:09 PM
gbvette62's Avatar
gbvette62
A customer of mine has a 68 with a Chevrolet 502/502 that I sold him. He's running one of the long L-88 hoods (the ones similar to a 78 hood, that eliminate the 68-72 wiper door). It's an aftermarket hand laid glass hood without the airbox insert. He runs a regular Chevrolet 14" open element air cleaner with no clearence problems. The top fender surround and engine position on your 78 is basically the same as the 68. I don't believe that the current Chevrolet 502 intake is any taller than the 68-69 L-88 intake. I've seen 69 with a Chevy 572's installed under the L-88 hood, and the 572 is a tall deck block. I can't believe that you would have clearence problems with the L-88 hood. There are plenty of 74-79's with big blocks and L-88 hoods. I'm sure someone on the forum has experience with this install.
Old Aug 20, 2008 | 04:33 AM
zuke6562's Avatar
zuke6562
I have a 69 vette with a 502. Am using an aftermarket L88 hood. Its not the one that covers the wiper door. No clearance problems. The fender line on your 78 should be identicle with the 69.
Walt
Old Aug 20, 2008 | 12:01 PM
Skunkvette's Avatar
Skunkvette
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Running a 1972 with 502, Eckler's L-88 hood (short version), Moroso full size air cleaner, no problems with clearance.
Old Aug 20, 2008 | 04:07 PM
rajsid's Avatar
rajsid
I also have a 69 with a 502 crate. A short Ecklers L88 hood worked for me. I am also running the K&N after market filter lids which barely clears the hood by 2 mils with a dropped base.
To 502 swap, hood clearance ?
