Still pulling to left after alignment
Aug 19, 2008 | 11:42 PM
So my car has pulled to the left for a while, had it aligned at work, still pulls, we swapped wheels side to side, didn't help, checked tire pressure as well...
Thoughts??
Kevin
Aug 19, 2008 | 11:53 PM
Have you tried to balance the power steering control valve? PG.
Aug 20, 2008 | 06:17 AM
if the ps is ok
try increasing the left caster
Aug 20, 2008 | 08:00 AM
Had the same thing happen with my Durango. Alignment was done, didn't help. Switched wheels and tires side to side, didn't help. Had it aligned again, still didn't help. Replaced the tires, good as new.
Aug 20, 2008 | 09:00 AM
Quote:
Originally Posted by
petes74ttop
Ok, how do you balance the ps control valve?
cc
Aug 20, 2008 | 09:01 AM
What is the condition of your front suspension (ball joints and a-arm bushings)?
Aug 20, 2008 | 09:28 AM
Aug 20, 2008 | 10:11 AM
Check your left front brakes. Your front brake may be draging causing your car to pull to the left.
Aug 20, 2008 | 11:01 AM
crf311
Could be either left brake-front or rear.
Caliper hanging up?
Parking break hanging up?
Bad ball joints?
Bad tire?
Steering power valve adjustment?
Camber?
Was it an oval track racer????
Aug 20, 2008 | 02:56 PM
CCrane72
cc
Simple procedure in the GM Service Manual. Might even be in the Haynes or Chilton manuals but I usually use the GM reprint.
Aug 20, 2008 | 03:06 PM
petes74ttop
100%
Aug 20, 2008 | 11:29 PM
thanks, I'll print that, give it to my tech tomorrow, see if he can balance the PS control valve...
Kevin
Reason: l';
