Quadrajet question
Old Aug 20, 2008 | 10:53 AM
a1sensei's Avatar
a1sensei
Default Quadrajet question
My carb gets very hot and I think I may have fuel boiling. I've heard of using an extra thick spacer gasket under the carb, but I happen to have two new standard spacer gaskets (1/4") sitting around and was wondering if there would be any problem with doubling up?
I've heard people talk of noticable performance gains using actual 1" carb spacers, but my hood claerance has never allowed me to try it. I thouight this might kill two birds with one stone (or two gaskets). Any thoughts? Thanks and God bless, Sensei
Old Aug 20, 2008 | 01:03 PM
...Roger...'s Avatar
...Roger...
Probably be ok but by spacing up is it going to cause a problem with any connections to the carb? If your using the gaskets with the 4 plastic spacers you mind end up with them loose in the center... then it could leak air.Try it but check air leaks.
Old Aug 21, 2008 | 11:05 AM
carbster09's Avatar
carbster09
Default Heat shield?
Why don't you try one of those heat shields? I have one lying about the garage somewhere! They are made my Mr Gasket I think. Its merely a thin alum plate that fits between the carb adn the intake. It helps disipate heat. Its cheap and might work! I never got around to fitting mine! Guess I did not need it!
carbster
Old Aug 21, 2008 | 04:24 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Check your heat riser valve on the right hand exhaust manifold. If it does not open, it can force too much exhaust gas through the exhaust crossover in the intake manifold, and therefore, overheat the carb.
Old Aug 21, 2008 | 10:19 PM
a1sensei's Avatar
a1sensei
Heat riser went away a long time ago.
Old Aug 22, 2008 | 12:09 PM
Kid Vette's Avatar
Kid Vette
Originally Posted by carbster09
Why don't you try one of those heat shields? I have one lying about the garage somewhere! They are made my Mr Gasket I think. Its merely a thin alum plate that fits between the carb adn the intake. It helps dissipate heat. Its cheap and might work! I never got around to fitting mine! Guess I did not need it!
carbster
Doc Rebuild has them. They were a stock item for a couple years.
Here are some pics showing the shield with my spreadbore Holley.
To Quadrajet question
