I pulled my car in the garage and there was this piece of rubber on the driveway. Its a partial piece of round rubber with the #'s 3795333, its about 3/4 of an inch thick and 2 inches round. I believe it came off the rear of the car. I drove the car hard and did not feel or hear anything strange. Could this be some sort of mount or bushing? The car is an 81 4 speed 383.
If it is your front differential mount don't get the one from Eckler's. I have that one and the washers that came with it disintegrated before I could get the torque to where it should be. I had to buy new hardware for it but I wish I would have just reused the hardware from the original now. I may still.
Thanks so much, is the car safe to drive until I have it repaired? How many mounts are there, and what else should I check for or have replaced? The car has the original 272 T10 rear with 85,000 on the clock. I would love to go 373 but everyones telling I would tear up the stock rear end with over 400 HP?
It should be okay to drive just as long the bolt did,nt break. You might just hear a little bang when you speed up or slow down, I,d take it easy though.
I just rebuilt my engine and it hasn't been on the dyno yet but I expect 400+ HP from it. I am running 3.73 gears in the rear with a Keisler 5-speed conversion. I haven't had it on the road yet but I know there are people here on the forum that run the stock 80-82 diff with a lot more HP than I have and have not broken anything. Then you get the guys that swear they will break with any kind of power. The way I look at it is that with street tires and street driving, I think the tires will give up traction before I break the diff. I guess I'll find out one day.
