Is the Carb bad????
Old Aug 20, 2008 | 06:32 PM
SpE3dF0x's Avatar
SpE3dF0x
Default Is the Carb bad????
Was wondering how can someone tell if the Carb is running bad? I recently added Lucas fuel cleaner and I noticed that when I stomp on the gas I hear a "pop-pop" sound at around 4500-5200 rpm with a "bog feeling. It still has the Ol'QuadJet on it. What do you guys think it is?
Old Aug 20, 2008 | 07:10 PM
bt57's Avatar
bt57
check the cap,wires and plugs before spending a lot of time, check compression you may have a tight valve,check vacuum it may have a major leak
Old Aug 20, 2008 | 08:31 PM
SteveG75's Avatar
SteveG75
90% of carb problems are really ignition problems.
Old Aug 22, 2008 | 07:33 PM
SpE3dF0x's Avatar
SpE3dF0x
It ran fine before I used the "ENGINE RESTORE" you know the one in the silver can(V8) and I use Full Syn(MOBILE 1) do you think
To Is the Carb bad????
