Flex plate cover
Old Aug 22, 2008 | 06:23 AM
BassCat's Avatar
BassCat
Default Flex plate cover
My '77 didn't have a cover over the flex plate when I bought it. The oil pan has a pretty good dent in it, so I'm figuring the flexplate cover got dented too. Anyway, I ordered a new cover from Ecklers. Can someone tell me if I have to remove the transmission lines to the radiator to install the cover? The lines both have fittings on them about 1-2 feet from the flexplate, going toward the radiator. If I disconnected them there, could I get enough play to slip the cover in behind the lines. I'm assuming the cover has to go behind the transmission lines. There's a slot cut out in the cover, but it appears to be for clearance of the starter. Just trying to find the simplest way to install this part, without disturbing too much. My wife thinks I have a tendancy to break one thing while fixing something else.
Kenny
Old Aug 22, 2008 | 10:44 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
There's enough play in the trans lines to get the cover in. Start it in on an angle.
Old Aug 22, 2008 | 11:32 AM
mrvette's Avatar
mrvette
I never put one of those covers back in some 50 years of driving, better cooling without it anyway....never saw the need for it once, .....
Old Aug 22, 2008 | 11:36 AM
sly vette's Avatar
sly vette
You mean you never checked to see if your clutch or torque convertor was still there???
Old Aug 22, 2008 | 12:11 PM
FB007's Avatar
FB007
Kenny
You can buy that from anywhere, why a Corvette supplier?
That dust cover is to protect the gear from gravel from getting jambed in there, and help prevent dust from getting to the front seal.
Old Aug 22, 2008 | 03:07 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
It has a secondary function too. If you have a leak in the front seal, the cover prevents the converter from flinging ATF onto your header collector, creating staggering amounts of smoke. With the cover in place, it just leaks on to the road. :o
Old Aug 23, 2008 | 06:02 AM
BassCat's Avatar
BassCat
Thanks for the help. After looking again, I think it will squeeze behind the lines. The cover was part of a larger order from Ecklers, along with headlight actuators, coolant expansion tank, power steering hose set, chrome master cylinder cover, and a dozen other little do-dads. I never seem to be able to order just "one" part for this car.
KC
Old Aug 23, 2008 | 06:15 AM
mrvette's Avatar
mrvette
KC
Victimized by the 'while i'm at it's eh??'...... the only true long term casualty in hotrodding is the pigskin....
Old Aug 23, 2008 | 06:48 AM
BassCat's Avatar
BassCat
Yep, it never ever ends. Everytime I think I've got this car the way I want it, I go to a car show or cruise in and see something else. My first thought is "hmmm, I need that".
To Flex plate cover
