I’m having brake/ booster problems on a 74 Corvette and I think it’s bad… did a search on another website and found this thread:
if you think the booster is leaking run the engine for a minute
shut it off and let the car sit for a while, then pull the check valve out- if there was a sucking sound (vacuum left in the booster) then its not leaking http://www.camaros.net/forums/showthread.php?t=135202&highlight=power+ brake+booster
Ran the car for a while and let is stand for 2 min. and the booster had no vacuum when the check valve was pulled. Main thing is no brakes – soft pedal. I’ve replaced master cylinder, front brake hoses and front calipers. Planning on replacing rear Calipers also… Just been throwing money at it but I would like to make a little progress…
What do you think? Bad Booster?
It sounds like you are on track. Since you replaced the master cylinder and front calipers, you should have that brake, if the booster was functional. Good luck and keep us posted on your success.
I did the search thing and I still think it’s bad… makes that swoosh / sucking sound. I doesn’t sound too easy to change but I guess I have to-to see if this helps out.
Mark (AKA Z28 Mark)
With the engine off, press the brake pedal repeatedly. Does it firm up quickly?
If yes, the booster is holding vacuum. If no, it's not holding vacuum.
If it firmed up and held vacuum, start the engine with your foot pressing on the brake pedal. Once the engine is started the pedal should soften and depress some. That's normal.
I agree with some of the above, but a soft pedal usually means air in the system. The booster may have a problem with the check valve or even a leak in the diaphragm, but the first issue is the soft pedal and that's not caused by a bad booster. IMO
The pedal doesn’t firm up at all (well maybe a little since the front calipers) but it goes straight to the floor. The C/V appears good… open one way and not the other. . I may replace the hose to the booster as it is as hard as ever. I’m using a vacuum pump (electric) and I believe that I’m getting most of the air out but it isn’t continues fluid when it’s being bleed. As I stated I’ll probably be doing the rear calipers today and then make the big decision about the booster… not looking forward to doing the booster.
Thanks for all the info and please keep it coming.
Mark (AKA Z28 Mark)
Bad booster usually = hard pedal, not soft. Also if the booster is leaking and not holding vacuum other strange things can happen - like your car starts not idling well, or the engine dies out or almost dies out, when you depress the brake pedal.
Is the booster push rod adjusted to length properly for your new MC?
You've got air in the system you need to pressure bleed the brake system. Vacuum bleeders just dont cut it on these 4 piston calipers.
You draw air from around the bleeder threads before it draws all the air from the piston reliefs in the caliper.
im having the same prob, but i replaced the brake booster last week, bleeded out thethe new calipers...( i have not put the down yet from the stands so i cant tell if i m brakeing or not)
but my pedel is frim if i hit the brakes with the car off... but when i turn on the car,, pedal hits the floor. i cant fig it out ether
Mark (AKA Z28 Mark)
Bad booster won't cause the pedal to go to the floor. It has to be in the hydraulic system. Either air or bad M/C
I think you may be right about the air in the system and the vacuum pump. May have to buy a preasure bleeder. Didn't cheek the rod on the booster before I installed the M/C. I too still have the car in the air and when I start it it goes right to the floor!
Mark (AKA Z28 Mark)
Mark (AKA Z28 Mark)
OK, first thing you do is go to a parts house and get a T fitting for the front brake lines....and fit it in there in place of the 'proportioning valve'....it's actually just a switch, then put the rear brake line directly to the rear section of the m/cyl....you will need a brass adaptor fitting in there, but been so long since I had a iron m/cyl I forget if it's front or rear....
give that a shot before you mess with the booster....it maybe bring enough pedal back for you....those brake bias switches tend to leak air but not fluids....I proved that long time ago....
I went through all these steps on my 1969. Ultimately, it was a bad brake booster. If your car has the original one in it, you might as well replace it anyway.....PLUS I suspect it will correct your problem. It is not tough to replace -- as I recall it took me about 30 minutes. Be sure to replace the hoses while you are at it.
