Front bumper, What am I doing wrong?
Old Aug 27, 2008 | 12:48 PM
koni9's Avatar
koni9
Default Front bumper, What am I doing wrong?
I can get my bumber to fit right. It feels like I have no more adjustment in order to suck the skin flush with the fiberglass.
Please review pics..... It's driving me nuts....
Old Aug 27, 2008 | 01:34 PM
reddog76's Avatar
reddog76
If this is a fiberglass replacement, it has to go over the metal "edge" close to the body. Also, even more important, if you are still using the rubber front cone underneath, then that has to be "ground down" to accomodate the new rigid fiberglass bumper. Every oe is different and mine took a lot of customizing to get it right. You should definitely try and use all of these support things in front. Also had to grind down the outside ones by the corners.
Reddog76in
Old Aug 27, 2008 | 02:03 PM
Jay-Dog's Avatar
Jay-Dog
When I replaced mine, I ditched the old formed retainers. For $30 or so you can buy a kit of individual retainers from Mid-America. This helped me alot. I've heard others say that they had to cut up the big rubber crash cushions on the car to get a non-OE bumper to fit. Mine was trueflex, it fit just fine with no trimming. Dumb luck maybe?
Jay
Old Aug 27, 2008 | 02:15 PM
koni9's Avatar
koni9
bumpers are original and i have an after market radiator.
Old Aug 27, 2008 | 04:11 PM
reddog76's Avatar
reddog76
It looks like it is not popping over the front metal ridge that is about 3/8" to 1/2" in front of the body area.
Old Aug 27, 2008 | 05:38 PM
koni9's Avatar
koni9
It is popped over the ridge.... Would my sway bar restrict movement foward?
Old Aug 27, 2008 | 07:29 PM
jd1a's Avatar
jd1a
It looks like you have replaced some of the brackets and other bracing. Are they the correct dimensions, correct for your year? Your sway bar should not affect the bumper mounts.
Old Aug 27, 2008 | 10:01 PM
koni9's Avatar
koni9
I got it!!!!!!!!! I just had to loosen some more bolts and jacked it in place and choked everything down. I am so happy, what a deal that was......
To Front bumper, What am I doing wrong?
