Another PCV valve question, cycle rate?
Old Aug 28, 2008 | 03:47 PM
dewm1's Avatar
dewm1
Default Another PCV valve question, cycle rate?
To get my 79 on the road, one of the things I did was put in a new PCV valve. When it's idling, the PCV valve sounds like its opening/closing super fast,, and when I take it out and plug the bottom, the motor idle smooths out,,, is this normal to have the PCV valve cycling so fast?
I know my distributor was bubba'd,, it needs to be reset one tooth and the vacuum tubing has been bubba'd to fix the removal of most of the polution control,,, so assuming the vacuum is hooked up correctly,, is the pcv cycling normal?, or should be "open" all the time at idle?
Thanks guys
David.
Old Aug 28, 2008 | 03:57 PM
thegazman's Avatar
thegazman
Default thegazman
Are you sure your PCV is hooked up to the right port on the carb? Do you have the stock Q-Jet carb? I assume your car is a 79. I have a 79 L82, but I'm sure the line routing would be the same. Let me know. I can take a picture of mine and forward it to you. All of my smog equipment has been removed.
Old Aug 28, 2008 | 04:07 PM
dewm1's Avatar
dewm1
thegazman,, if you could send me your routing picture, that would give me an excellent start.
As far as I know,,, I have the original L48 motor and carb. I haven't done any number matching research yet, with as far as I know 28K miles,, I haven't yet felt the need.
Many thanks!
David.
Old Aug 28, 2008 | 05:51 PM
thegazman's Avatar
thegazman
Default thegazman
David....Here's a photo of my PVC and vacuum advance routing. As you may notice I have modified most of smog equipment; however, the PVC and vacuum advance lines are still attached in the same place on the Q-Jet carb as the original.
Old Aug 28, 2008 | 05:59 PM
pws69's Avatar
pws69
PCV Valve must be connected to straight MANIFOLD vacuum, typically at the center of very base of a carb. - the largest nipple on the carb
Old Aug 28, 2008 | 08:32 PM
dewm1's Avatar
dewm1
thegazman & pws69,,, many thanks,,, now I have something to play with tonight.
Once I get the PCV/vacuum/advance lines straightened out, I can find #1 TDC and reset the distributor and do a little timing.
Thanks again!
David.
Old Aug 29, 2008 | 09:10 AM
dewm1's Avatar
dewm1
I found the distributor at least one cog off,, it's sitting in correct now and it takes just a quick flip off the key to fire instead of a 10 second crank. I used a vacuum gauge to prelim set the timing and this weekend buddy is bringing his timing light. The PCV valve tubing does come off the correct port, but a vacuum line splits off it and runs to the fender fume cannister. The PCV valve still cycles like a sewing machine(?) I checked the PCV vent line and there is definitely suction there when the PCV valve is in so it is working,, maybe a different valve will stop the cyclic clatter,, any suggestions?,, and instead of 220 degrees at idle, the gauge never went over 200(195 thermostat) the whole time it was idling.
One thing I'm still struggling with is the dual snorkel flap vaccuum,,, the flaps with no vacuum stay open, and with vacuum they close. Just the way it should be,,, because Bubba got into the vacuum lines sometime(s) over the last 30 years, and he disconnected the lines,,, could someone help me with getting the snorkel flap tubing back to the way it should be so they work properly?
Edit after: Is this the answer? http://forums.corvetteforum.com/show...snorkel+vacuum
Thanks for all the help so far,, this is a great forum with great people.
David.
Old Aug 29, 2008 | 05:15 PM
SH-60B's Avatar
SH-60B
David.
It has to be the PCV valve for that specific motor. Sure it's the right one?
Old Aug 30, 2008 | 02:04 PM
Paul L's Avatar
Paul L
Good point. There is even a difference between the L-48 and L-82 PCVs in 1979.
Old Sep 4, 2008 | 02:57 PM
dewm1's Avatar
dewm1
SH-60B and paul67,, buddy at NAPA asked if it was a L48 or a L82,, so I have to assume it's the right one,,,.
There's more tuning and rebuilding of the carb and distributor in the near future so once that's done with all the vacuum tubing replaced, then we'll see what it's up to.
Thanks!
To Another PCV valve question, cycle rate?
