1976 headlight
Old Aug 28, 2008 | 07:26 PM
1986coupe's Avatar
1986coupe
Default 1976 headlight
I am working out the vaccum problems with my 1976 Corvette. One headlight is up and locked in place. How do I manually get it to drop down (don't worry, I know not to push on it) so that I can drive it in the day without being embarrassed while I work out the vaccum issue? It normally never gets driven at night so I didn't know there was a problem.
Thanks,
Bill
Old Aug 28, 2008 | 07:35 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Just reach up under the car through the valance panel. You will see a cast (pot metal) link with a rod passing through it. On the rod are springs, Passing through the rod is a clevis attached to the actuator. Push toward the actuator and the light should come down.
Willcox Inc.
Old Aug 28, 2008 | 07:40 PM
KevinK's Avatar
KevinK
Yup, just feel around for it, kinda like a latch for the hood to lift up on some cars. You'll find it.....
and if you're like me, you'll know it by heart, it being the only way to get your lights down after a little evening driving, lol.
Old Aug 28, 2008 | 07:54 PM
1986coupe's Avatar
1986coupe
Thanks!
Old Aug 28, 2008 | 09:01 PM
...Roger...'s Avatar
...Roger...
Actually if it is LOCKED you will probably have to pull down where bolt #8 goes through the pivot arm to UNLOCK and allow the actuator rod to go back towards the actuator.
Old Aug 28, 2008 | 09:37 PM
Glassbowtie77's Avatar
Glassbowtie77
Just reach up under the grill and grab hold of the big hole in the end of the actuator link bracket and pull it down on it slightly . It will release and the headlight assembly will close.
Old Aug 28, 2008 | 09:50 PM
76 VETTE's Avatar
76 VETTE
Mine was stuck open and it was the vacunm filter.Good Luck
To 1976 headlight
