I think I have a 168 tooth flywheel. 1974 Auto 350.
Should I go with a regular starter that I can get for around 100 or should I go with the ministarter. Besides the 12 pounds of weight you save, what other benefits are there if you go with the mini.
I saw some on Summit for 119-139 and Jegs for about 170.
I use this rule, if it is a high Compression Motor,
I go for the Gear Reduction, they use less current,
and crank the motor over easier.
Mini's never crank over slow, not even BB.
