Question about power steering valve
If anyone can shed some light on how the system converts mechanical input to hydraulic output, I'd be grateful Like I said, the valve is installed and working great...but as an engineer, I just feel I have to know. BTW...I'm an electrical engineer, not hydraulic, so forgive my ignorance. Thanks.
If you will notice, there is an adjusting nut on the end of the cylinder where the pitman arm connects. This is used to balance the oil flow so that when you are not turning the steering wheel there is no oil flow to either end of the cylinder. This is where the bypass comes in that is on the pump. The bypass allows the oil to simply circulate within the pump. This bypass is located behind the high pressure hose connection that screws into the pump. It consists of a small piston and a spring. This bypass and the balance adjustment keeps you from"fighting" the wheel when turning and when not turning.
One slight correction. When you are NOT turning the steering wheel the control valve (on the relay rod) is in "free flow" position. Power steering fluid exits the pump discharge valve #24 and freely flows through the control valve and back to the pump reservoir. In this position, the pump only sees the pressure required to flow the oil around the system (50 to 75 psi).
The pump is a positive displacement device. The faster it rotates the more fluid it displaces. After about 1200 rpm the pump would begin to flow far more fluid than you could ever use. So there is a linear valve #6 inside the pump (located right behind the discharge fitting #24) that limits the amount of oil that can flow out of the discharge fitting. So the Corvette pump linear valve and discharge fitting are calibrated to work together and allow 1.6 to 2.9 gallons per minute (depending upon the model year of your Corvette).
Now when you start to steer, the ball stud on the control valve begins to shift to one side or the other, this causes a slide valve inside the control valve to block a portion of the flow, raises pump pressure, and opens a port which directs pressure and a limited amount of flow to one side of the assist cylinder or the other.
When you reach a full lock turn, you are completely blocking the flow and the pump now "dead heads." To prevent the pump from destroying itself, there is an internal pressure relief built into the linear valve inside the pump that allows fluid being pumped to be recirculated inside the pump. Vette pumps are set at around 950 psi. This pressure setting prevents damage to the Corvette hoses or the control valve. However even in this pressure relief, recirculation mode, the power steering fluid quickly heats up and can cause damage to the pump if it is held in full lock for more than 5 or 10 seconds.
Jim
