Which sway bar?
Old Sep 8, 2008 | 01:02 PM
  #41
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Originally Posted by gkull
If QA-1 would make a shorter 700 lbs coil over spring I would test it. But call QA-1 and ask them what springs they recommmend and they are stuck on this spring weight per front end pound chart. they claim that a lapping vette can't even use a 450#. I have the 550# and need to cut about an inch out of it.
You can always bulldoze the springs to shorten them to the desired height.
Old Sep 9, 2008 | 01:10 AM
  #42
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
gkull, I've gone thru some of the same oiling issues here, and have an Accusump ready to install myself. 8-qt, 5-gate, "RR" pan won't quite cope...
I swear I ran across a source somewhere for 700's with a free weight set for C3's when Yellow73SB ended up with short ones, but maybe I just dreamed it 'cause I can't find any notes on it...
Old Sep 13, 2008 | 11:03 AM
  #43
gkull's Avatar
gkull
Originally Posted by ctk30
Your car is all over the place in the corners
Oh really? How much smoother can I be? In a lower powered car your not really racing are you? This video doesn't really show what it is really like in the car when your going over the rumble strips at 120 mph. All you hear is the sound at the start of the video
I only 3-4-5 gears around this 4.2 mile track. With a top speed of mid 150 mph. Also those squealing tires ar Hoosier R-6 slicks 295/35/17 in front and 335/18 rear
http://s124.photobucket.com/albums/p...50513_x264.flv
