427 block decoding.
Old Jan 5, 2002 | 04:05 PM
WESCH's Avatar
WESCH
Default 427 block decoding.
Hi
A good friend of me has a spare 427 block
Casting 3904351
also got following codes
M5460 and H3450
Any ideas what it is, what year ?
Thanks Gunther :seeya
Old Jan 5, 2002 | 04:10 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: 427 block decoding. (WESCH)
You should find the casting date on the bellhousing flange up near the distributor hole. Don't have my books handy, but 351 is a Corvette block as I recall. Chuck
Old Jan 5, 2002 | 04:25 PM
1Bad69's Avatar
1Bad69
3904351....427.......67......2 or 4 bolt...this info is from mortec.com...
Old Jan 5, 2002 | 04:26 PM
DaBo's Avatar
DaBo
WESCH,
3904351 is a casting code for a 1967 427 block. Used for 2 and 4 bolt main blocks, HP dependant upon application.
Where are you seeing the H5460 and H3450 numbers?
Should also be some stamped numbers on a casting boss by the water pump, these will tell date and application.
Post any other numbers and I will try to decipher for you.
Hope this helps,
DaBo
76 Moodvette
62 Roman Red.
Old Jan 5, 2002 | 05:00 PM
Allan71's Avatar
Allan71
Default Re: 427 block decoding. (Chuck Gongloff)
Date code actually moved there in mid-69, earlier big blocks will have the date code down on the right lower side of the block near the freeze plug and starter.
Old Jan 5, 2002 | 07:38 PM
DaBo's Avatar
DaBo
Default Re: 427 block decoding. (Allan71)
I stand corrected.
Thank you
DaBo
76 Moodvette
62 Roman Red
To 427 block decoding.
