I would look to change the squirters and pump cams first. The Cams will change the ammount of fuel and the rate it is delivered, while the squirters change the ammount only.
If I was to go to a 50cc pump would I put one on the primary and secondary or would I just buy 1 an put it on the secondary.:
On my 427 sb, I installed the 50cc pump on the primary side and also installed larger squirters on both the primary and secondary sides. You definitely need this for your 600+ horses.
I have a Quick Fuel 950, but I believe your Demon flows similar CFM. Don't be shy with the squirters, I installed #42's front and rear.
The secondaries with the large squirters should overcome the need for a 50cc rear pump.....you'll have to judge by driving. Good Luck
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by 69Vett
my very old Holley double pumper, Orginally had a 50cc on the rear only,
it is a spreadbore carb.
Are you stumbling on acceleration ?
When I go WOT the engine hits like a ton of bricks then a slight 1/4 second flat spot then it's off to races again right to redline. It's almost like peddling a blower car when it comes on again the tires spin.
Anyway not a big deal I new I would have to tune the carb for the bigger motor. Seems like the pump shot might not be long enough or something. Actually at this point it could be any one of many things, I only have about 150 miles on the motor. I just got some bigger squirters ( I know a smaller squirter will give a longer pump shot ) today and I am going to try a few other things before going to the 50cc pump
