75 Wiring Help
Old Sep 10, 2008 | 03:25 PM
Dkbluevette89's Avatar
Dkbluevette89
6th Gear
Default 75 Wiring Help
Hi, i'm replacing the tach in my dad's 75 vette, when i was under the hood i came across some problems. The 1st problem is, the brown wire that goes to the dist. has no tach filter, their should be one bolted to the intake manifold under the dist. is that right ? The 2nd problem is, a orange wire from the harness that goes no where, looks like its been cut and was wrapped in masking tape. Any help would be great. I have pics if i can figure how to post them in this message.
Old Sep 10, 2008 | 05:53 PM
Sully1882's Avatar
Sully1882
yeah gonna need some pics and more detail... for sure that orange wire could go anywhere... it's a 12v power source and could go to the clock or the courtesy lights or a number of other things... do you have a wiring diagram? get us some more detail or pics and maybe we can help...
good luck,
Sully
Old Sep 10, 2008 | 06:41 PM
BHRIG's Avatar
BHRIG
Default 75 wiring help
You are right... the brown wire should have a filter on it and goes to the dist...
The other wire probably goes to washer pump on bottom of washer reservoir.
Old Sep 10, 2008 | 07:02 PM
'75's Avatar
'75
This should help, it's Durango Boys istruction site.
http://photos.imageevent.com/durango...g%20Images.pdf
Old Sep 11, 2008 | 10:59 AM
Dkbluevette89
6th Gear
Thanks guys, got a pic loaded but its big. The orange wire i put on top of the spark plug wire comes right from the harness. Its really long and able reach the other side of the engine compartment. Now the brown wire for the tach, should the tach filter be right there bye the dist. or down along the fire wall where the harness clips in under the brake booster ? Appreciate the help !
Old Sep 11, 2008 | 12:50 PM
TopGunn's Avatar
TopGunn
The tach filter is supposed to be bolted to the intake in that tapped hole just under the edge of the dis cap in your last picture. What is that silver can in the picture? Looks like it's threaded into the dist shaft area right under the red power lead to the dist.
Old Sep 11, 2008 | 02:30 PM
Dkbluevette89
6th Gear
I believe its the oil pressure sending unit, any ideas about the orange wire in the picture
Old Sep 11, 2008 | 02:41 PM
TopGunn's Avatar
TopGunn
Oh OK, it's screwed into the hole in the rear of the block then. Mine is down at the oil filter.
I'll look at mine later tonight if you don't get an answer first on the wire.
Old Sep 11, 2008 | 02:52 PM
...Roger...'s Avatar
...Roger...
There are not too many orange wires under the hood.Is there a wire connected to the blower motor?
Old Sep 11, 2008 | 04:08 PM
johns73's Avatar
johns73
What tranny is in the car, If a turbo 400 the orange wire my go to the kick down on the driver side of the tranny
Old Sep 11, 2008 | 07:21 PM
tobyte1's Avatar
tobyte1
If the orange wire comes out of the main harness plug, it is for the security key switch on the drivers front fender. If it comes thru a grommet on the firewall, it goes to the fan blower. Good Luck
Old Sep 12, 2008 | 07:15 AM
TopGunn's Avatar
TopGunn
I looked at mine last night, the orange wire is either the alarm or the blower. Based on the size in your picture I'm betting it's the alarm
Old Sep 16, 2008 | 02:18 PM
Dkbluevette89
6th Gear
Default update
sorry been gone for a couple of days, just wanted to post an update.
Well i checked all the suggested locations for the orange wire but the tranny, everything seems to be in place. Security lock orange and red, blower black and purple, just have to keep tracing. Now the real pain, installed the new tach board and nothing, at a loss. all the trim pieces where missing screws or mixed. has 2 be because of the person that rigged in a junky 8track radio. found a stock radio on ebay for $99 thinking about buying it thank god the wires are still there. Heres a pic of my nightmare. thanks for all your suggestions.
Old Sep 16, 2008 | 03:03 PM
TopGunn's Avatar
TopGunn
I feel your pain See below. On Tach board, only suggestion I have is make sure it's grounded but others might have a better idea. I bought a laminated wiring diagram from Dr. Rebuild, I'll look to see where I put the darn thing and scan orange wire locations for you later.
Old Sep 16, 2008 | 03:39 PM
71406's Avatar
71406
does your heater fan work on the highest speed? On some cars there is a relay for the high speed that is powered by a connection on the horn relay. The wire connecting the two crosses over the motor along the firewall similar to what you have in the photo. Best bet is to get a schematic.
Old Sep 17, 2008 | 05:46 AM
Bob Walker's Avatar
Bob Walker
I might be from across the other side of the planet, but the issues are similar.
I couldn't figure out the orange wire either, but it ended up being for the kickdown on the tranny. The wire seemed too long, but the type of connector on the end (which you don't have) gave the game away.
I also replaced the PCB on the Tach, but it still didn't work. In my case the phenolic (insulating) washers were missing from the two mounting screws, so there were some serious short circuits. I used some "O" rings and fixed the problem. By the way, my engine wasn't finished, so I temporarily hooked the tach to another car I have with a Chevy engine to see if it worked or not. I've included a picture of my own nightmare, made worse by the addition of alarm, front & rear parking sensor and central locking wiring.
Old Sep 19, 2008 | 04:19 PM
Dkbluevette89
6th Gear
Default Good news
Good news, got the tach working, turns out that it was the washers that bob suggested,(had them installed backwards lol) very greatful. The car idles around 13/14 rpm, only prob. the needle doesn't zero out when u turn the car off, only when you turn the key back too accesories. Think this because the tach filter is missing? I'll check the orange wire for the tranny kickdown after i get the interior back together. I have to move the car to the other side of the garage/more room to jack and get under it. Thanks again for all the help. Best forum on the net!
To 75 Wiring Help
