rocker arm stud torque
Sep 10, 2008 | 08:00 PM
i needed to replace the guide plates in my 72 BB.
i did some measuring and they had 5/16 diameter guide plates and push rods which i discovered were for small blocks.
my searching has found two torques to reinstall the rocker arm studs when i put it all back together. 45 ft/lbs and 60 ft/lbs.
which one is correct. neither of my manuals give a torque reading for that stud.
thanks
Sep 10, 2008 | 09:05 PM
I usually do 60 lbs in iron heads...I have no idea if that's 'proper' or not, and if you'd need to do less with aluminum heads.
Sep 10, 2008 | 09:33 PM
sweet thanks,
other than just stupid,
why would someone put small block pushrods and guide plates in a big block motor.
Sep 11, 2008 | 07:59 AM
Quote:
Originally Posted by
baxsom
sweet thanks,
I don't really understand how small block plates would even fit on big block heads.
Small block Guide Plates:
Big Block Guide Plates:
Sep 11, 2008 | 08:26 AM
baxsom
sweet thanks,
That would be impossible.
Sep 11, 2008 | 01:02 PM
maybe so but without a shadow of a doubt the guide plates bolted into my heads have 5/16 holes matched to 5/16 pushrods.
i cant find anything that says that big blocks ever used 5/16 pushrods.
i called summit and they in turn called comp cams
neither one of their tech depts knew of any 5/16 pushrods or guide plates for the big block
(ps those pictures dont show up)
here is a pic of my current guideplates as well as my dial calipers measuring the pushrod slot showing 5/16.
Sep 11, 2008 | 04:27 PM
Those are not small block guide plates.
Sep 11, 2008 | 05:26 PM
ok then that explains that then but not why such small guideplates and rods were installed in the first place when everything i have read says that 3/8 or 7/16 were standard in big blocks
did big blocks ever come with 5/16 pushrods.
i cant find anywhere that says it did.
