Big Block timing
Old Sep 12, 2008 | 01:07 AM
75_yellow's Avatar
75_yellow
Default Big Block timing
What is a good rough guess that i should look at as far as timing on my big block total advance and base settings?
Old Sep 12, 2008 | 01:53 AM
Peterbuilt's Avatar
Peterbuilt
Base timing is between 4* to 12*, check out BarryK's Sticky ( at the top) for great info, PG.
Old Sep 12, 2008 | 02:06 AM
FB007's Avatar
FB007
Idle 16* .36* at 2800 RPM. 52* with vacuum advance engaged at 3000 RPM
Old Sep 12, 2008 | 06:51 AM
baxsom's Avatar
baxsom
idle at 16*
is that a good estimate for all big blocks
i know the book for my 72 454 says 8* i believe so i just wanted to make sure.
Old Sep 12, 2008 | 08:25 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by baxsom
idle at 16*
Whatever it takes to get to 36 at about 2500-3000 RPM's. My big block is set at 12 initial to get 36 total.
Old Sep 12, 2008 | 09:03 AM
sxr6's Avatar
sxr6
idle at 16*
The only reason manu's set base timing so retarded is because it creats hotter gases flowing thru exhaust to burn unwanted pollutants. The only reason!
As above says, set timing at 36* (38* if cammed) with vacuum unplugged at 27-2800rpm! Depending on vacuum canister that should give you 45-50* with vacuum plugged in. Let idle timing fall where it may, means nothing anyway, as long as it rolls easily on starter.
A rollback timing light is a great device for this kinda stuff, wish I had one of my own
Old Sep 12, 2008 | 09:26 AM
slapshot 496's Avatar
slapshot 496
This really is a loaded question! If the motor is stock,,heads and cam mainly.Then the manual is likely a good starting point however if you have a longer duration cam with increased overlap then you will have to increase your initial accordingly!! but as the previous post stated "initial" really isn,t a huge concern ..unless the starter is binding..so fiddle with the initial but keep the total between 34-38.You can also use a vacuum gauge ..look for the highest reading ,if it,s really low increase your initial until it peaks this will get you very close..cheers
Old Sep 12, 2008 | 11:52 PM
Jeff_Keryk's Avatar
Jeff_Keryk
My stock 68 427/390 distributor has 16* centrifugal advance, so the 4* factory setting is pretty close. 4 + (16 times 2) = 36 total. I do use lighter springs to bring it in faster...
To Big Block timing
