Stereo
Old Sep 12, 2008 | 10:05 PM
damlie's Avatar
damlie
Default Stereo
First off, I know nothing about sound systems. I bought a car w/ a big stereo in it. However, when I turn the volume up, the stock speakers really vibrate a lot. Wouldn't you normally disconnect stock speakers if you were going to put in a big system? If not, what should I do to correct this problem?
Old Sep 13, 2008 | 09:38 AM
Durango_Boy's Avatar
Durango_Boy
Can you outline what you mean by big stereo? Having lots of speakers doesn't count. A big stereo would be an after market head unit, a large amp...maybe two, and some speakers and a sub.
If you can tell us what components your stereo has I can help deduce what's wrong or missing for good sound.
Old Sep 13, 2008 | 10:13 AM
MrGoFaster's Avatar
MrGoFaster
If the stock speakers are rattling at high volume then there are a couple things you can do.
1 try to adjust the power input to them to a lower level. Adjust the fade more toward the rear / bigger speakers. Also try adjusting with the main volume at around 75%-90% not max. Most big systems that sound really good don't have every **** everywhere on max.
2 they may just be old, tired, blown, dry rotted etc. If adjusting doesn't help then its time to replace with an upgrade.
3 If the speakers seem to be good but you've adjusted them so low its ridiculous then they may just be overpowered from the time they were installed. Time to start checking numbers & get better speakers.
If you get speakers with a higher wattage than you're stereo or amp can give them then you'll get a good 10-15 years out of them. If you go under they may blow right away or just not last very long. Try to avoid off brands as they tend to always display huge numbers at low prices & just suck like sparkomatic. Look for a big magnet. That will tell you if it really has oomf. Pioneer, Kicker, Sony, Kenwood, etc etc All good brands at a decent price. You can consistently almost always get anything you see in the store on ebaY for less than 1/2 price with shipping included.
Old Sep 13, 2008 | 10:20 AM
Durango_Boy
Originally Posted by MrGoFaster
Look for a big magnet. That will tell you if it really has oomf. Pioneer, Kicker, Sony, Kenwood, etc etc All good brands at a decent price. You can consistently almost always get anything you see in the store on ebaY for less than 1/2 price with shipping included.[/COLOR][/SIZE]
I'm sorry but that just isn't true. The magnet itself may be big and cheap with poor motor and cone design and the speaker will sound like poop. Not trying to pick a fight, just clearing that up a bit. wasn't meant as rude at all.
Yes, some very good speakers do have large magnets but that doesn't mean that every speaker that has a large magnet will sound great. I have a set of Hitron 6.5" speakers I use for demonstrations and fittings because they have massive magnets. The truth is they sound worse than anything I prefer to use that has a smaller magnet.
Old Sep 13, 2008 | 10:50 AM
Five-spot's Avatar
Five-spot
Stereo equipment is like pretty much everything else in the world. You tend to get what you pay for. You didn't mention the make and/or model of vehicle, but for the sake of discussion, we will assume that we are talking about a Corvette. Most speakers of the C-3 era have paper cones. these tend to dry out and disintigrate with age. When this happens, they tend to either quit working or start sounding like crap. Also, if you have a system that generates a lot of bass, mounting bolts will vibrate loose,which will give you a tinny sounding vibration.That being said, more information is required re: Brand and wattage of head unit, size and location of speakers, size of amp, etc.
Old Sep 13, 2008 | 11:14 AM
MrGoFaster's Avatar
MrGoFaster
It's all good Durango
Sorry, that did sound a little all encompassing. I think I should elaborate with an example. If you've got a 15" speaker & the box says 2000W for $30 & its got a 1oz magnet somethings not right somewhere. I think we've all run into that type of scenario with off brand stuff in the past. It sounds like hes starting from scratch so I was thinking from that perspective. Anyway, dismiss that statement & just go with name brand.
Old Sep 13, 2008 | 01:43 PM
1nicecorvette's Avatar
1nicecorvette
in other words here. it sounds like whoever put the equipment in that car either put speakers that were not rated for the wattage of the amplifier or stereo pushing them. or they just left the factory speakers in there and are pushing those. either way what your problem is, is distortion. match the RMS wattage of the speaker with the power source. if the speakers say they can handle 300 watts RMS that means 150 watts EACH, 60 RMS is 30 and so on. so take that into concideration when buying new speakers.
Last edited by 1nicecorvette; Sep 13, 2008 at 01:44 PM. Reason: just plain cant spell
Old Sep 15, 2008 | 04:49 PM
damlie's Avatar
damlie
I'm not even sure what a head unit is. There is a large amp and two large speakers. Takes up a lot of room behind the seats....
Old Sep 15, 2008 | 04:53 PM
damlie's Avatar
damlie
It's just the stock speakers in the front of the car that i have problems w/. The after market speaker in the system are behind the seats (with an amp in between them) and sound just fine.
Old Sep 16, 2008 | 12:56 PM
CaptainHook's Avatar
CaptainHook
Pictures? These guys are really good. They can tell a lot from pictures. BTW, how do you know you have stock speakers? Maybe they are aftermarket speakers in stock location.
Old Sep 16, 2008 | 01:35 PM
Backstop's Avatar
Backstop
The head unit is the part in the dashboard that has the radio and/or CD player or tape deck. The part that sends the signal to the amplifier in the back. If you have big speakers behind the seats you may as well just disconnect the factory speakers in the dash.
Old Sep 16, 2008 | 06:46 PM
damlie's Avatar
damlie
good point on both accounts. i'll take some pics.
damlie's Avatar
damlie
OK, cool; thanks.
Old Sep 16, 2008 | 07:03 PM
damlie's Avatar
damlie
Old Sep 16, 2008 | 07:05 PM
damlie's Avatar
damlie
there are the pics. the speakers say "CS-XV 6930" and the amp or sub or whatever (the 2nd pic) says "realistic."
Old Sep 16, 2008 | 08:30 PM
1nicecorvette
someone went the extra mile to uh install a stereo system in your car! some advice? remove everything after the radio!
as for the front speakers they are only 4x6 and im sure if stock are dead after being hit with the wattage off the head unit. after 30 years that paper speaker is dust to begin with.
this is an easy project for you to do. you can 1 of two things.
1- replace the front speakers with a nice plate setup. that is a 2 1/2 or 3" speaker with a 1" tweeter together on a plate and installs where the factory speaker lays. easy
2- you can replace with a regular 4x6 and add a capacitor inline of various values, to raise the HZ (hertz) to lets say 500. more technical.. i would go with the first idea. here is a pic of what im talking about
NOTE: THE HEADUNIT IS THE STEREO ITSELF
To Stereo
