Motor/Transmission Mounts
Old Sep 14, 2008 | 02:05 PM
willem wallace's Avatar
willem wallace
Default Motor/Transmission Mounts
Need to order a new set of motor mounts and transmission mount. Engine is a GMPP crate ZZ383, and the stock mounts I have from my 1971 small block bolt right on. The transmission is a turbo 400, shorttail. My question is the best mounts to use. The motor will be about 400 HP and I am running the performace rear end gears, 3:36. Any info is appreciated, especially aftermarket part numbers.
Old Sep 14, 2008 | 02:35 PM
SmokinBBC's Avatar
SmokinBBC
I am using the energy suspension on my BB. Only have 3k on the car since I put them in, but no problems. They have a search by application on ther web site.
Old Sep 14, 2008 | 08:26 PM
willem wallace
Default heat issues?
Does header heat present any problems with the poly mounts?
Old Sep 15, 2008 | 04:35 PM
FKING1's Avatar
FKING1
Bought polyurethane motor & tranny mounts from Year One for my 70 L46. Poly better than factory rubber.
To Motor/Transmission Mounts
