slow headlights
Old Sep 15, 2008 | 12:02 PM
Dryoo7's Avatar
Dryoo7
Default slow headlights
Lately I've noticed that the driver-side headlight is much slower to open than the passenger side. Is this normal or a sign of a vac. leak somewhere?
Chuck 1981 vette
Old Sep 15, 2008 | 12:11 PM
Oldguard 7's Avatar
Oldguard 7
Usually one side will open up faster than the other. If it is really slow, check for vacuum leaks in the hoses that make up the vacuum system controlling the headlights.
Old Sep 15, 2008 | 12:48 PM
1nicecorvette's Avatar
1nicecorvette
air, like fluids; will go to the path of less resistance first. hense the one opening faster then the other. if its really off like a second or two then go with the above and check for a leak on that side.
Old Sep 15, 2008 | 11:20 PM
TNX ZORA's Avatar
TNX ZORA
When our '73 developed the same symptoms I found the fix was rebuilding the canisters with new rubber diaphragms. All the hoses were and still are original but the diaphragms got cracks in them.
Old Sep 15, 2008 | 11:28 PM
DC3's Avatar
DC3
My '73 does the same thing. Drivers side is very slow. I've traced my problem to the rod seal on the actuator.
DC
Old Sep 15, 2008 | 11:42 PM
BigBlockTank's Avatar
BigBlockTank
I replaced all vacuum hoses on my 69, problem fixed! You may not be as lucky, good luck
To slow headlights
