CA & headers ??
Old Sep 16, 2008 | 02:44 PM
merrell.a's Avatar
merrell.a
Default CA & headers ??
I have an 81 w/all the emissions for Cali. Does anyone know if it is possible to upgrade to the exhaust manifolds w/headers and still be able to be smog legal? If so who makes it?
Old Sep 16, 2008 | 03:32 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Hedman used to make a CA legal set of headers. They came with smog tubes and 50 state and CARB stickers. When I tried to get a set a few years back, they seem to have been discontinued.
I'd start with their web site and go from there.
Realize, however, that if you still have the stock catalytic converter, you'll never notice any difference with headers. the 2:1:2 design and pancake cat means that threre is a severe restriction point, especially when it's old and clogged.
Old Sep 16, 2008 | 04:30 PM
fauxrs2's Avatar
fauxrs2
Hedman 68281:
Yes they technicly are not CA approved, however I've had a set for 10 years, tested at least 4 times at state run stations and never had a single comment. The truth is if the Emissions are all connected and working 99.99% of testers will pass you on visual.
The comment on pancake cats is right on, those are by far the worst thing you can put in your exhaust, however if you replace that pellet based convertor with a high flow unit then headers start to make some sense.
Old Sep 17, 2008 | 01:40 AM
merrell.a's Avatar
merrell.a
Originally Posted by fauxrs2
Hedman 68281:
Yes they technically are not CA approved, however I've had a set for 10 years, tested at least 4 times at state run stations and never had a single comment. The truth is if the Emissions are all connected and working 99.99% of testers will pass you on visual.
Thanks gentleman, it currently has a fairly new muffler system with magnaflow mufflers. I am not sure what kind of cat it has though. I am looking to get a high flow cat. would you recommend keeping the x style tubing system or use two straight seperate exhaust with 2 high flow cats? My biggest concern is finding headers that I can use in CA, and mantain the look of most of the emissions connect to the exhaust.
Old Sep 17, 2008 | 09:16 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Headers are no problem. Mine are Hedman #68301 and Fauxrs also gave you his part number.
Old Sep 17, 2008 | 09:51 AM
fauxrs2's Avatar
fauxrs2
Dual exhaust dual cats wont be legal and will likely get caught by the inspection station. You can have a custom exhaust setup where the head pipes from the headers Y into a 3" pipe and then go through a 3" hi-flow cat - out of the cat you Y back into the 2 1/2" pipes.
this is essentially the same cross-sectional area as 2" duals (though not as efficient most likely)..but it will make a noticable improvement over the restrictive factory system. most important is smooth transition in the 'y' pipe as opposed to the virtual 't' junction used in the front factory pipe.
Old Sep 17, 2008 | 01:47 PM
merrell.a's Avatar
merrell.a
Will it have any affect on making the exhaust rumble any better. It sounds decent now but would like a little more louder without being real obnoxious. Thanks again
To CA & headers ??
